- Apr 12, 2013
- 562
My grandfather's old Atlas is up and running well in my shop, except for the continual low frequency wobble/shake.
I have checked and double checked the legs and adjustable feet.
It still shakes with no chuck mounted.
Changing the speed with the 4 step pulley does not affect shake.
Changing the speed with the 2 step massively speeds/slows the shake.
There is a visible bounce to the motor that corresponds with the shake. I can slip a wedge under the motor and the shake stops. Recall that on this lathe the motor is mounted on a hinged plate and its weight provided the belt tension.
There is a visible side to side wobble in the 2 step idler pulley, likely from storage damage.
I have tried with moderate success to straighten (by the grab and twist method) the idler 2 step pulley. I held some chalk near the side so it would just touch to mark the axis and just gave it progressively harder pulls and pushes. It is quite flexible IMO. I would say I got half the side to side movement out...but no more. I'm wondering about possible up/down offsets and/or balance issues, but that is hard to see.
Is there a better way the poorly equipped home hobby shop could get this pulley closer to true?
Should I just put an adjustment screw/bumper under the motor to stop the bouncing since the non-rigid motor mounting seems to cause most of induced shake? Would this hurt anything?
I know I can (or could last year) get a replacement pulley...but that is not particularly cheap.
