Hi,
Joined the forum yesterday. Have a mini-lathe and mini-mill. Waiting for some tooling to arrive before I can start making chips. Was looking at having the ability to make R8 collets (as a starter project to learn a bit about lathe and mill operations).
Is this likely possible on my cheap lathe and mill, or are the tolerances going to be too tight - bought a dial gauge to try help set up the machines? Also to do so, I'm assuming I should buy some 33mm (just over 1.5") round. What grade of steel should I look for (was tossing up between M1020 and M1030) unless you guys have other recommendations?
Also what size steel should I stock? I was thinking if I buy a flat bar say 200mmx6mmx6m (about 8"x1/4"x20') and the 33mm round to start with, then I should be able to make machined boxes out of the flat, or build it up in layers if additional thickness is required to make solid shapes, whilst the 33mm round should give me some ability to make round objects?
Any thoughts appreciated.
Cheers,
XXXX_guy
Cheers,
XXXX_guy
