- Apr 12, 2013
- 562
After what I thought was properly seating the new bearing race, finishing assembling my headstock, and making some test runs, I was trying to do some serious work today.
http://www.hobby-machinist.com/threads/drilling-hardened-steel.36275/
While plunging a 1/4" 2 flute endmill I had issues. Besides requiring a lot of pressure, it started to chatter all of a sudden. On close inspection, the cutting edge chipped out. I tried again using the side to walk the hole over. SNAP!
While taking the mill out I felt the spindle shift. It had developed several thou end play. ??? I tightened the preload collar and went to work again, figuring it was just the left race not seating fully. New mill. Grabbed into the work and seized the mill...stalling the whole lathe. Now over 0.050" end play has appeared! Another mill trashed. This tiem I broke out the plastic deadblow hammer and whaled away on the left end of the spindle (yes I had a thread protector!) several times, I got over a full turn on the collar before end play disappeared, and I'm really worried!
No signs of any other trouble. I think maybe the left bearing race was in a bind previously, instead of seating square, and it finally straightened out and settled into place when I put it under a working load...but I'm a little concerned. Is there something else I need to be looking at???
