I found a Bridgeport BOSS CNC 'project' and have managed to bring it back on line. The mill itself is in great condtion, the ways are chromed and the motors / ball screws are smooth and accurate. All very good and unfortunately still way above my pay grade.
I am trying to make parts but am stuck writing g-code directly. This weekend I:
1. Forgot to raise the z axis before I repositioned the x axis and ran the edge finder into a vise, scratch one edge finder - minus 4 points. I was able to figure out how the edge finder worked + 1 point.
2. Ditto above error on a #30 drill in a piece of work. Minus 4 points on the error and minus 2 points for making the same mistake over again.
3. Similar error: At the far end of aa x axis travel I issued a combined x, y command to return to home. The y movement took the drill edge into the vise face and acted like a mill cutter. Minus 4 points + minus 4 more for making a similar error.
4. The last straw: I had a piece of bar stock down in a vise. I was using a centering bit to mark drill locations and forgot to notice the top of the centering bit would run into the vise face as I move along the x axis. The bit took off a good piece of the vise face. Beyond grading, kind of like driving a car into a cement lamp post.
The good news: I was able to make initial interchangeable parts. They fit together and the design idea was solid.
I need to find a good CAD/CAM tutorial to get started. I have to believe it would help with some of the above errors. All in all today is a new day.
Thanks for reading, Dan
