The lathe that I bought recently doesn't have a backsplash so I need to make one from mild steel. I by far would prefer to stick weld this project. Gas welding is my only other option at home and I don't want to gas weld this project. The AC welder is an old Lincoln, so old that it has copper windings. It only goes down to 40 amps. I have very limited experience stick welding anything thinner than 1/8" thick. I would like to use 20 or 22 gauge to keep the weight down; 18 gauge is an option if 20 or 22 is too thin. I don't see a backsplash needing a lot of structural strength. I can bend the backsplash in a sheet metal brake but the ends will be welded on. I'll also bend a self for tool holders and other small items from the same material. I'm thinking 4 " wide on the shelf.
What is the lightest gauge steel that is reasonable to weld at 40 amps with 1/16" 6013 with a reasonably good chance of not blowing through? Is there a better rod than 6013 for this application?
I have that welder. You're asking a lot of it to do stuff this small.
One workaround (if you can work with it.....), is while you can't (with any practicality, and ESPECIALLY with limited experience) weld 20 or 22 gauge metal directly, you can do a PITA workaround. If you make your corners with a piece of angle of the right length ( let's say 3/4 X 3/4 X 1/8 ish, or whatever. Nothing "heavy", you can let the angle make the corner, hold the sheet back an eighth of an inch (or a quarter), so the angle is technically inside, but "exposed" at the very point of the corner- Then, working from OUTSIDE the corner you can start a puddle on the angle without obliterating the sheet, then drag the puddle over to the edge of the sheet, so as far as the sheet is concerned, you got in and out real fast, even though you didn't.
Don't do this on the inside of the corner. Only from the outside, where the sheet is "backed up" by the angle.
It does (pretty much) require a careful drawing, or otherwise plan the layout precisely, as the angle does become a part of the overall dimension.
You will be tacking. Even with an appropriate welder you're gonna have a tough time making a full seam on flat sheets on the best of days, as all the stresses have no place to hide, so they end up as big ugly wrinkles.
What rod? What can you run best? I'd do what I said above with (literally) whatever one I had a surplus of. Probably 6010, 6011, or 7018,. The 6013 you mention is pretty smooth and predictable, it should do fine. I'd probably use 3/32 or 1/8, for no other reason than that's what I'm likely to have. 5/64 and 1/16 are technically better suited, but they're an art unto themselves to work with.
You would set the welder up to burn a solid weld into the angle, and bank on the quickness of "dragging the puddle onto the sheet" to make up for the insanely inappropriate weld that's about to happen to it.
If that sounds like something that might be within your skill set, have at it. If you aren't 100 percent positive, try playing with a small sample to see how it works out for you, maybe figure out how far to get the bead into the sheet before you back out.
