I have a Miller 250 amp AC/DC stick welder. It seems to me this would make a good power source for a TIG. Does anyone sell an add on TIG (with HF) that would work with my welder?
I don't speak TIG so I don't know if a need a specific waveform or pulse. I have a stick and a MIG (both Miller) but have no aluminum welding capability and that is what I'm after.I was thinking the same with my Lincoln Weld-N-Power a year ago and was looking at HF add-on boxes.
However, consider that a HF box won't necessarily do pulse, also check to be sure if you are getting a HF starter or continuous HF.
Do you want/need to be able to adjust the waveform?
It may depend on what you intend to TIG.
I'm not suggesting that the HF boxes are a bad idea, just be sure that you are purchasing a box that meets your needs.
Daryl
MN
You can mig weld aluminum, all that is required is DC. On heavier stuff, you could probably get away without a spool gun using a 1/16" filler wire. For lighter spool wire, you'll need a spool gun.I don't speak TIG so I don't know if a need a specific waveform or pulse. I have a stick and a MIG (both Miller) but have no aluminum welding capability and that is what I'm after.
Thanks, I'll check out that site.
I don't know anything about MIG.
And I'm certainly not a professional welder. Others here are...
However, I do enjoy TIG, and enjoy laying down an occasional aluminum TIG weld.
I believe you will want AC, continuous HF, and pulse for aluminum TIG.
Consider spending some time on:www.weldingtipsandtricks.com
Should you want to travel to MN I'd be glad to spend some showing you TIG.
Some say that TIG is the most difficult, as it requires two hand coordination.
If you ask around you might find a HM member closer to your home that will set you up with a TIG torch for a few hours.
Daryl
MN
I would rather TIG aluminum than MIG it. Mig just doesn't have the controllability of Tig being as soon as you pull the trigger you're off to the races, filler wire and all. I've had aluminum MIGged in job shops and was rarely 100% satisfied. Stuff I had TIGged was always perfect. TIG is what I'm after.You can mig weld aluminum, all that is required is DC. On heavier stuff, you could probably get away without a spool gun using a 1/16" filler wire. For lighter spool wire, you'll need a spool gun.
