- Jan 2, 2019
- 7,160
I've been using these steppers which were generously gifted to me by a fellow forum member with TB6600 drives.
But when I mocked up a direct drive for my Z-axis it became clear it just doesn't have enough umph for that configuration. Doing some research it looks like they're rated at 131oz/in which is on the lower end for Nema 23 motors.
I already have some DM542 drivers that I was planning on using with my Mesa Electronics controller upgrade and I see that Nema 23 is readily available in 270oz/in and 425oz/in versions. I've also seen that folks typically use a bigger motor for the Z-axis then X and Y. The little motors I have seem to work okay for X & Y but I did notice them struggling a bit on deep cuts.
So, I'm thinking of getting two 270oz/in for the X & Y axis and a 425oz/in for the Z-axis.
Any thoughts?
Thanks,
1ohn
Any thoughts?
Thanks,
1ohn
