E
ecdez
Forum Guest
Register Today
I need to make a part in steel. After being machined to shape it has to be tapped on one end and then surface ground on two planes and have a reasonably attractive finish. The tapped hole needs to hold up to some medium level abuse; probably 3/8x16 threads. Typically I use 1018 for all my stuff. I was just going to run with it for this part too but I've never ground 1018 and don't know how it would fare compared to other grades. Should it be fine or is there another easily accessible grade that would be better?
Another consideration is forgiveness. I have a terrible time with steel (compared to aluminum) and a nasty habit of breaking end mills. I don't think I want to use anything too hard. I normally use a carbide rougher and a finisher.
Any suggestions?
Any suggestions?
