- Jan 7, 2016
- 3,374
I am in the process of restoring a Wilton Vise (model 840, 1951 vintage). I am looking for opinions on the grade of metal to use for the main handle. I need to have reasonable strength and machinability. I will be turning the ends down to accept turned "balls" that will be peened on and polished. I don't believe any welding will be needed on these parts. Once the parts are done they will need some resistance to corrosion, although maybe just a light oil coating will suffice. I have/am considering nickel plating but not sure yet about that. It is something new and fun I do want to try.
So, my choices available on Midwest metals out of Rogers MN are as follows... --->Midwest Metals Rogers, MN<---
1018. BLAH! I hate that stuff, especially when it comes to machining.
12L14- Machines very well but very difficult to weld is my understanding.
8620 - Don't really know anything about this alloy. Any insight would be appreciated.
4140 - Also known as Chrome Moly. I am somewhat familiar with this alloy and is at the top of the list for this project.
Just wanted to run this by you folks to see what your thoughts are.
Also, I have some shafting that linear bearings ran on. They came off of the work stations I bought. Very precision stuff.... --->Work stations<---
My question is.. how does one go about cutting this. I tried my bandsaw and I'm afraid I just dulled the teeth on the bi-metal blade. I chucked a 3/4 diameter piece in my lathe with a carbide insert, and it does turn down but holy cow, the swarf is smoking hot. Actually looked like it could start on fire but the finished cut was pretty good.
