There isn't very much machining on these outdoor lights but they certainly qualify as an "Other" project. They're part of my 12 volt outdoor lighting. Each light uses a 1 watt blue LD and a 1 watt yellow LED that wants to be orange. The near light uses an LED driver instead of just a current limiting resistor will be brighter until I upgrade the other light. For 2 watts of energy apiece, there is a lot of light. As you can see, there's a lot of plumbing parts incorporated.
If you're not familiar with Steam Punk, it's science fiction based on steam powered machinery. I haven't figured out how to efficiently use steam power to power the LEDs.
