- Apr 5, 2013
- 391
I just got done with a part , simple part but it did provide a challenge for my Atlas/Craftsman 6"101.03701 lathe . The part is a spacer , 120mm (2.75) length 3/4 dia . tapped 3/8-16 each end . For one thing I kind of screwed up , I used the 4 jaw (should of used the 3 jaw) so me wanting to get both ends running at least with in .005 , the 3 jaw would have provided that at the chuck end . So first I had to get the chuck end dialed in , no need with the 3 jaw . My steady rest has just the brass fingers so when I went to indicate in the other end , I got it running + or - .005 , it was to tight to start the lathe . I need the fingers with the roller bearings at each end . I like buying tooling .
Mark .
Mark .
