- Apr 12, 2013
- 562
I have an original Atlas steady rest for my 10F. I was wanting to build roller fingers for it to work some aluminum rod, as I figure the standard solid fingers would be too hard on aluminum...and it would be a good learning project. In the interest of ease of machining and lack of rigidity on my milling attachment, my goal was to use aluminum barstock and small sealed bearings for rollers. This is a rare use item, so longevity is not a major concern. Is aluminum (probably 6061T6 due to ready availability) going to be strong enough? The pin for the bearing support would be steel, just the body would be aluminum...3/8" square IIRC, which gives slightly less than 1/8" on each side of a 1/8" bearing.
