- Feb 9, 2017
- 5,526
I made the first version of this several years ago and being v1 it was more proof of concept. I used very crude v block clamp and a couple of 80/20 drops along with a spare 80/20 guide bearing in order to make the height adjustable. It proved to be so handy it made me mad I didn’t do this years ago. This is the v2 with more solid mounts, rack and pinion height adjust, a locking knob and a slide stop. The original had just Allen screws for snugs and was quick to make but clumsy in use. I also welded the beam clamps to the frame to ease mounting as I don’t leave it set up. When I made the better grinder mounts it was necessary to pull the front housing off the grinder and put it in the lathe as it was tapered. this made it stronger and easier to mount. Hopefully the photos are self explanatory. Any questions just shoot and I’ll do my best.
