The machine is a Bridgeport CNC with a 2 HP 2J2 head. The project is to mill a lathe spanner wrench for a L-0 lathe spindle. The raw material is 1/4 x 4 x12 hot rolled plate. I can writh the J code to do the milling. My question is what should I set the mill head rpm, cut depth, and cutting speed, IPM. The cutter is a 1/4 inch end mill.
