- May 13, 2019
- 1,016
All,
I bought a PM-25MV mill about a month ago hoping to convert it to CNC. You can see my thread regarding this purchase here: Possible Purchase of PM-25MV. I figure I should move this discussion here since it's no longer about purchasing and moving the mill, but about CNC conversion.
I plan on using Fusion 360 for CAD/CAM which I'm finding is not easy to learn. The 3D aspects are new to me as are the CAM part. I'm sure I'll have questions on this topic. I'm assuming Fusion 360 questions are okay to post in this forum? I also plan on using LinuxCNC (LCNC) for the control software. I'm very familiar with Linux so this shouldn't be an issue. Of course, the CNC part of it is new.
I have a few options for the PC that will run LCNC. I have access to a used PC from work. Specifically, it's Lenovo ThinkCentre M92p with 240 GB SSD and 16 GB of DDR3 memory. I installed LinuxCNC 2.7.14 on it and ran the latency test and got around 23,000. From what I've read, this is decent and usable. However, the issue is there is no parallel port, only Ethernet. Rather than buy a Mesa card with more complexity I decided to buy a new motherboard (ASRock Mini ITX DDR3 1066 Q1900B-ITX) and use the SSD and memory from the Lenovo PC. This motherboard has a parallel port built in.
For the rest of the parts, I plan on using:
DM860T motor driver with a NEMA34 1000 oz-in stepper motor for the Z axis
DM542T motor driver with a NEMA23 400 oz-in stepper motor for the X axis and Y axis
ST-V2 Breakout Board
For the last bit with the ballscrews and mounting hardware, I haven't fully decided yet on which way to go. I can either buy a kit from various sources (ProCutCNC, arizonavideo, etc.) with all the parts or I can buy each separately and mill the mounting hardware. I'm looking for advice on this aspect.
All comments/advice is welcome! Thanks!
