Put my main hydraulic project and dro project on hold. Tired of cranking the handle on the mill. Working on building a power feed, from the idea of the socket disconnecting motor, if that’s the way to put it. using a window motor.. lathed An inch round stock down to 3/4 to for about an inch. fit in my er32 hex collet holder. Mounted on the mill and milled down each side of the hex to fit in a 3/4 socket. Then I slowly milled the end of the socket to fit the drive end of the bed lead screw. Drilled and tapped each for a 1/4-28 grub screw. Build the plates and slides tomorrow. I have a drive that may work for the motor will see coming up. That was my afternoon.
