Started band saw
chatter chatter cut cut
Jun 21, 2021
139
conversion from wood to metal cutting . got a metal cutting blade and made 4 pulleys . two 10 in and two 3 in diameter. full stop. hurt back , now using a walker and pain pills around the clock. dont know when i will be able to anything in the shop for a while.
What blade speed range will you have when you are finished? I attempted to reduce the speed on my Enco 4-pulley band saw and couldn't get slow enough by rearranging the pulleys to max reduction ratio, and gave up until I can put a VFD on there. I guess if you're stuck at one ratio you can adjust your tooth pitch to something that would work and swap blades as needed.
Spondylitis here, 4-6 Norcos/24hrs- Wish I could get Oxy, they last longer
hoping to get 85 to 160 final blade speed. the present motor pulley is 3 in to a 5 in to 12 in blade pulley.its really going to take a real sit down with calculator and some mental sweat .
Sorry to hear about your injury!
at least that can be done while you rest your back.
Take care of yourself.
Brian
I too have a bad back. I have to use a stool when working at the lathe or mill after a bit.
Standing for >20 minutes will cripple me. Got to keep moving.
Yes, welcome to the bad back club.
Hope you find relief soon.
