Standard Modern 1334 Tapper Attachment
JFI
Jan 16, 2014
7
Hi Everyone, I recently picked up a 2003 Standard Modern 1334 lathe with a taper attachment that is a permanent attachment on the rear of the cross feed table. I am trying to take it apart and remove it for cleaning & maintenance and some painting . It is amazing how it works together yet independently with the front hand wheel. A genius designed it but how do I remove it? Has anyone had any experience with removing one. I have gotten to a point where I am a bit nervous and don't want to break anything! Thanks, Joe
If you could post a few photos someone might recognize the design even if they don't have the same brand of lathe. Most cross slides that I have seen come off with only a bolt or two.
http://www.mwdropbox.com/Dropbox/_2001_retired_files/standardmodernarmy15.pdf this is not exactly the same but may be similar.
http://www.lathetalk.com/library/standardmodernarmy15.pdf this may be the same as above (backup link)
http://www.ebay.com.au/itm/STANDARD...the-Operators-Parts-Manual-0706-/290691874632 or you could buy this one.
John
