- Jun 8, 2016
- 635
I'm making a steady rest for my 12" Logan.
I'm starting with a cut off of 4140 basically 4.75" OD, 3.25" ID.
That I will clean up and make pretty on the lathe, the weld a base to it with support of hot rolled steel.
I'm familiar enough with 4140 to know welding can lead to cracks in the HAZ. I'm planning to tack it together and put the whole assembly in the oven to 350*F. Then weld, and then back into the oven, letting it sit at 350 then simply turn the oven off and not open it for several hours.
The welds won't need to be machined after. I don't need any special strength from the 4140, it's just what I have to work with.
So, finally my question.... welding. I can stick weld it with low hydrogen rods, or TIG weld it with stainless, likely 309. Other than a slow cool down I can't post heat treat. Is stainless my best option? If not what would you suggest?
