My boss from a past job would respond ........................." Wear earplugs " . He was an ID10T .Any ideas on what I need to do?
Them as can, do, them as can't, boss.My boss from a past job would respond ........................." Wear earplugs " . He was an ID10T .
Thought I'd test the waters here before I really get into her start taking things apart
You don't put grease on a Bridgeport feed screw. It should be oiled with way oil. Do you have a one-shot lube?Well Jim you made my day.
I carefully took my servo 140 off, cleaned it all up ad I went...took a look under my carriage and greased that lead screw. Put it all back together and it worked like a champ...no more squeaking..
I luv ya man and this site, thanks guys.
It's probably full of grease.You don't put grease on a Bridgeport feed screw. It should be oiled with way oil. Do you have a one-shot lube?
