- Jan 3, 2013
- 192
I have created a spreadsheet to help with spring winding calculations (This is actually version 3, and will be the final version unless any errors crop up which need to be corrected).
The spreadsheet offers three options:
Option 3, in theory, would give the same results as Option 1, but in testing I have sometimes found small differences. My guess is that the table probably is more accurate for large lathes in a production set up, and that Option 1 is more accurate for small lathes in a hobby set-up (but this is purely a guess).
I have tested the spreadsheet as best I can, and I believe it to be free of any errors, but of course I cannot guarantee this; if anyone else tries it out and finds a problem (and lets me know!), I will make the necessary corrections.
You can download the spreadsheet in LibreOffice and Excel versions here:
https://sites.google.com/site/lagado...g-making?pli=1
P.S.
The above link also includes links to other information on spring winding.
- Mandrel: Calculate the mandrel size needed to wind a spring of a specified diameter.
- Equivalent: Given a set of spring parameters, find the parameters for a spring with the same spring rate but with a different wire size, diameter, number of coils, etc.
- Table: A simple lookup table to find arbor (mandrel) diameters for winding music wire springs of a designated size.
P.S.
