- Jun 17, 2011
- 2,069
Recently, there has been a fair bit of mention of spring tool holders. The purpose is to allow the holder to flex when the cutter tries to dig in. The flexing is done in such a way that the cutter will bend down and away from the work. Normally, any flex in a lathe toolpost will allow it to flex down and into the work, causing chatter.
The first video I saw on the topic mentioned that they are often used for holding form cutters, such as could be used to make the shaped handles for lathe feed screws. With this in mind, I made mine to take either a standard 3/8" HSS tool or a wider form tool.
I saved a lot of machining by using the portable bandsaw to slab out large sections. This also leaves a few pieces that can be used for other projects.
In looking at examples of factory-made spring tool holder, I saw that some had an insert in the bottom, bridging the spring gap to provide some sideways rigidity. Easy to do, so why not? Note that the spring slot is cut last, since its purpose is to take out some of the natural rigidity of the holder.
The finished tool holder. You can see the side tool slot, which could be used for a threading bit or a small form tool. The third setscrew at the far corner is used with the corner one to hold a wide form tool across the front of the holder.
I haven't cut anything with it yet, so I can't give you a report on how (or whether) it works.
