- Jan 12, 2019
- 12
I just got a small lathe and am eager to start on a project to install a QCTP. Quick question, what spotting drill would you use to start an M10 tapped hole?
If I'm not mistaken the 'proper' method would be either
- 90 degree spotting drill, larger diameter than the tap drill, or
- 120 degree spotting drill, smaller diameter than the tap drill
I see lots of youtubers using centre drills for starting holes, but is that really a cromulent method?
