- Mar 2, 2021
- 84
Hello!
I’m working on machining and scraping a cast iron straight edge from a raw casting.
There is a ton of information out there about spotting one of the faces of the straightedge (like the shoe) using a surface plate for scraping.
When it comes to spotting to adjacent faces (like the shoe and the back) to scrape for squareness, is the common method to use a granite master square sitting on the surface plate?
If so, do I need to rig up some kind of way to clamp the granite square to the ledges of the surface plate? Or is it enough to just blue up the face of the granite square sitting on the surface plate and push and rub the straightedge up against it (while also resting on the surface plate).
I looked in the usual sources like the “Machine Reconditioning” book but wasn’t able to find info on scraping a casting square.
I know another technique would be to make three squares and scrape them square to each other, but that’s a lot more work than I was hoping to do.
Also, I don’t yet own a granite master square but was looking at some 4-face granite parallels (where all four of the long sides are flat, parallel and square to each other) as a “cheaper” alternative to buying a large 5-face square. $900 vs $1700+ In particular a set of 1.5x3x24”. My thinking is to rest the 1.5” face on the surface plate, and blue up and rub against the 3” face. Thoughts?
I tried buying a budget $250 granite square from Shars but only the two long 1” thick working edges are square (ie a two face square) and even those two faces weren’t very square, so I returned it.
Would love some thoughts from more experienced hands before I go investing in some higher end granite accessories.
Thank you for reading!
