- Aug 22, 2012
- 4,271
I expect the cognoscenti already know this but I just had to mention it as I was so impressed with the results.
I had to drill and tap 15 x 5mm holes in some hot rolled steel.
Usually I use the standard taper tap to start followed by the intermediate and bottoming tap.
I start the taper tap in the drill press (no power) to start it straight then release the chuck, transfer to the vice and use the tap handle to complete the threading operation.
All 15 holes were straight through so no need for the bottoming tap.
In this instance I used a spiral point tap and am amazed how much easier and faster it was.
I started all the holes by hand, they didnt require much in the way of pressure to start and I swear they pulled themselves straight as soon as they started to cut.
I am so impressed that I will purchase a spiral point in all my most used sizes.
