So my spindle woes continue with my Bridgeport I dunno if they're supposed to be this loud as I've never ran a series 2 before so I've take some videos to hopefully help out. The video shows the machine powering up and winding down. Now I don't know if these other problems are related but I think they might be. The cutter had a wobble to it which I noticed by eye and I put an indicator on it an measured .003" the video shows this as well. And with the spindle just free spinning the load meter reads around 80-85% and goes down to about 60-65% when I take a cut. First video is the start up and wind down second is the cutter wobble. Also in high gear the lowest rpm it will go is about 1000 which leaves a 600rpm gap from the top of low gear. Not sure how to go about fixing that either.
