I am trying to learn how to use my new to me milling machine. Doing some projects and practice on mild steel. Using 4 flute end mills, mostly 1/2 inch. I am running the mill at the slowest non-back gear speed (660 RPM). Seems to extrude more than cut the metal. These end mills came with the machine, and may be a little dull. I am doing manual feed on the Y axis and feed speed does not seem to change this. Is this spindle speed too slow?
