- Mar 19, 2011
- 940
A reference chart that I found online said for a 2" diameter cutter, on mild steel, ~200 rpm. I'm using a 2" face mill, with 3 inserts. It looks awfully slow to me. Did I miss something?
Even with a hand fed speed of dead slow, I'm not getting a really good finish. I can see the swirls.
And while I'm on the subject: I understand "roughing cut, conventional; finish cut, climb." So how does that work with a face mill? Should the work (1/2 inch wide) be run down the middle of the mill, or off to one side of the center?
