- Jul 6, 2022
- 513
Hi All,
Some of you may have seen my other threads that identified that my lathe has some pretty bad spindle runout - 0.08mm / 0.003inch. This runout can be measured inside and outside of the spindle.
It was suggested that if I were to make my own chuck back plate on the lathe itself, the backplate runout would mean that the only runout measurable would be down to the chuck itself. If my understanding of that is true, my question is this: if I make my own chuck backplate for my 3 jaw chuck and make my own ER32 collet chuck (that fits directly to the spindle) - will the spindle runout become a non concern? Or will I go through this effort of creating these back plates to find out that I’ve another issue further down the line? Like if there’s wear now, will the wear get worse and I’ll start seeing more runout.
Sorry for the vagueness of the question, but I don’t feel I have enough knowledge to ask the question in a more constructive way.
Thanks In advance.
Thanks In advance.
