- Sep 29, 2017
- 2,307
I have two questions for the experts out there and it is merely for information sake,about lathe spindle nose cones and chuck backplate registration on the nose cone.
Say you make a new backplate, do you need to make it that the backplate register on the cone and flush up against the back of the spindle? Because it could be pretty difficult to get it to mate against the cone and spindle plate at precisely the same time. My head tells that that is the way it should be and that is the way I did a few years ago for my new chuck, but with a lot of fitting and removing the backplate.
Secondly, if the Spindle nose is a bit worn or damaged, is it advisable to regrind it on the lathe using a TPG or some grinding device before making a new backplate?
Food for thought.
Michael
Food for thought.
Michael
