Spindle Holder For PM-833TV
Skowinski
Nov 9, 2017
222
Not even sure this is worthy of a separate thread, but here goes....
Once I took delivery of my 833TV I quickly discovered there was no good way to hold the spindle while tightening the drawbar. After getting numerous suggestions on here, and contacting Priest Tools about whether one of their power drawbars would adapt, I decided to make my own for now. Eventually I do want a power drawbar, but that's further down the line, after a DRO etc.
I bought a PTO Adapter, Sleeve Type, 1-1/8" 6 Spline Female, 1-3/8" 6 Spline Male from All States Ag Parts, cost about $23 shipped. The ID of this thing is a good match for the 28mm spindle splines.
It had some kind of plating on it (yellow zinc?), which I didn't want to weld, so stripped it in a Muriatic Acid bath for 2 hours, along with a couple of pieces of 1/4" square steel bar I had that was zinc plated. That did the trick, but left some flash rust, which I removed with a steel brush on the drill.
I grabbed a piece of 1" diameter HDPE that was laying on the shelf and chucked it up in the lathe, turned it down, shaped it, and bored a blind hole in it to produce an interference fit with the 1/4" bar I made the handle out of. Welded it all together, ahem as best I can weld, painted it, and pushed the handle on, nice and tight about a 100 thousands interference fit.
Works like a charm and for a total cost of probably $25 and a few hours of fiddling in the shop.
One day I'll figure out how to adapt a Priest power drawbar and this little cheap tool will be history, but it'll do the job for now. I should have used larger square section steel bar, but this is what I had laying around, and it works fine. Don't laugh, I had fun LOL.
Doesn't make sense that it wouldn't come with one built in especially at that price range
Yeah, well I was surprised.
Easy fix in the end. Apparently a lot of people are just using a butterfly impact wrench....
