- Mar 5, 2021
- 55
So this evening I was running some aluminum nothing aggressive on my pm727v converted to cnc with spindle control via kbsi240d board and acorn . After about 30 minutes into the run I noticed the rpms fluctuating just enough to hear i kept running and about 5 mins after hearing the rpm change the spindle dropped way low almost cutting off . I slapped feed hold maybe thinking I needed to give the tool time to catch up although I was not hogging . After letting it catch up I felt of the spindle motor and it was hot too hot to touch knowing better I kept on running and soon after the spindle shut off . Has anyone had this happen ? I have not changed the bearings (yet) and it is the factory variable speed motor that comes on the pm727v . Does anyone have any suggestions on what I need to start checking ??? Could this be from the kbsi240d board not being spot on ???
