There are two belts on the machine. Each speed listed has a corresponding belt combination. The first part (a letter) corresponds to the position of one belt, the second part (a number) corresponds to the position of the other belt. The diagram labels the belt positions: Starting at the top, the front pulley has positions A,B,C,D from top to bottom and the back pulley has positions 1, 2, 3, 4.
So if you pick 2280 rpm from the chart, that corresponds to belt combo A-2 : the front pulley has a belt in the top position connecting to the middle pulley and the rear pulley belt is connected to the middle pulley on down from the top. (Edit: assuming 60Hz)
HTH,
GsT
