Will , what DON'T you have ?This one?
Everything that is nice and/or expensive!Will , what DON'T you have ?
This morning I started looking on Amazon for cheap refractometers. After 20 mins I thought, "ya dummy you already have one!". Went and dug it out & found out that I have 2 of them, a cheap one & a not so cheap one! And to be honest, I can get by perfectly fine without one.Will , what DON'T you have ?
Yes, for checking coolant mixtures. And I don't even run flood coolant!They are for checking coolant mixtures ? I haven't used one since 99 ! That base on the left ..................I think I just pulled the same one out of my box in here at work last night . Does it start with the letter K?
Does anyone out there have a Pittsburgh multi-position magnetic indicator base from Harbor Freight? I need to know the diameter of the vertical pole and the dimensions of the magnetic base without the mag switch lever.
Yep. That one. Thanks!This one? Don't mind the mag base that's on it now, it was left over from something else & I just threw it on there for storage. The mag base that came with it was repurposed for the lamp.
It's top secret. I could tell you, but then I would have to kill you.Just curious, but why do you need to know any of this?
I also wouldn't depend on any of these measurements, because HF will change them without notice. You can buy something from them one month, then say, "I really like this product, I think that I'll go pick up a couple of spares..." go back to the store and find out that that same thing is the same, but different.
