- Aug 2, 2020
- 683
Nutfarmer's home spun fixes are great and got me thinking of a few fixes I have made on my own tractor.
These Ford row crops are not rare but certainly were not high production machines.
Most of the steering parts are no longer dealer serviced.
The bearings in the upper steering column were flimsy little things and Ford provided no way to lubricate them. Add to that, water tended to get into them which was Not condusive to longevity.
Mine had rusted and disintegrated so badly that you couldn't even measure them for generic replacements.
I pressed the U joint apart so I could chuck the splined end and use a live center in the other and took a skim cut on the shaft to clean it up.
I bought some delrin and made some bushings to replace the original bearings then pressed them into the tube. Made the fit on the shaft fairly loose ~ .005
I greased the shaft well before installing it.
Between the upper and lower bushings there is about 5" of wear area.
The steering is Way smoother now than with
the crunchy bearings that were in it.
I hope the photos help tell the story.
