- Nov 21, 2010
- 1,602
Time to time I post a long time problem of figuring out how the oil intake to the pump is plummed.
This is on a 1917 Roberson the hydraulic style lift system. The pump stroke runs of the main shaft
eccentric. The oil output is a no brainer (i just used sink flex pipe) The problem is, my thought would
be >it has a trough around its casting which I think it would be the oil resevouir. If the case (there is
no threaded hole anywhere . Oh I can make it work by making a hole but I would like to know how
It was done when mfg. I target some of the newcommers here that havent seen my old posts about
this and maybe have the same machine. epilog > oil output ok pump does pump ok problem cant
find where it gets its oil. here is the pump pic 2 flex pipe pic 1
