South Bend Taper Attachment
ShagDog
Recently bought a South Bend 9a lathe. It came with a taper attachment (not attached). I am trying to confirm it is a genuine South Bend; looks to be. It also looks like it has everything; except the part that ties it to the lathe's cross slide.
It would appreciated if I could get help in confirming it is a South Bend, and it is complete; except, the mount described above.
If I'm not mistaken there is a completely different cross slide for a SB taper attachment.
I wish I had that cross slide as I'd build the rest of the stuff.
Hope this will help.
Thanks. Helps a lot. Looks like like all that is missing is the slide block that goes on top and the washer and lever. Should be easy enough to fabricate since there is no dovetail on top.
That's not a SB model - the dove tail is on the wrong side. Here's a SB model that shows the UNIT NUMBER (TA100) and the SB LOGO stamped on the headstock end.
Thanks; but certainly not what I was wanting to hear. Mine looks just like the one in David's picture above. I also looked at this website and it looks like the one in "Fig. 2" with the dovetail on the bottom. http://www.wswells.com/data/howto/9_taper_Install.pdf
I took some more photos showing more numbers but did not find a SB emblem. There is a # "100"; but no "TA" in front of it. Here are the additional photos. The last 2 are of the same number, just different angles. Not sure how to read that number.
