Can you guys tell me about these lathes. are they basicly a good lathe? how much do they usually sell for? Can you tell by the picture how old it is? I dont have the serial number. It has 3 and 4 jaw chucks and some tooling. It at a local auction.
Thanks
looks like a very good lathe from the pictures--it is a quick change so others can give you a better est of value, but I would say if all the gears are good it would be worth at least over $900.
A model A South Bend is a good lathe. Around here that lathe (depending on tooling) would be in the $1500 range. That lathe has a quick change as someone mentioned and also has power cross feed. It look like it has a thread dial on the right hand side of the lathe. On the smaller South Bend lathes that was an option. The stand that comes with it is worth a few hundred bucks by itself. Good luck.
