I have a 9c and want to cut 5/8 24 threads. I haven't changed gears before, so I pulled off the gears that were being used before I purchased it and cleaned all the gears. When assembling the gears (stud gear 16, an 80 and 48) I noticed that the lower gears align, but they don't align with the stud gear. I can see (photo #2) that the previous owner ran it this way (witness marks on the gear behind the stud gear). What is the solution to this problem? Shim the two lower gears or face the gear behind the stud gear.
Scott
Scott
