The chart I have states that the cone pulley should be kept full of oil only when using backgear.I also posted on PM and yes it was said to always oil the thrust bearing with oil. So that settles that. Now I went by what the book says to put Super Lube in the cone pulley. Now I'm hearing I should remove the super lube and just use oil. It's easy to remove the spindle at this point and clean away the lube and just use oil. I've read a lot of post's so far on this topic and it seems like it's a 50/50 choice.
Yes but I read that if you use super lube on the cone pulley you should not use so much that it might contaminate the thrust bearing and ruin the bearing. I think I'll just pull the spindle out and remove the super lube and just use oil. Besides the pulley says oil not lube.Lubing the spindle bearing will also take care of the thrust bearing.
