This is a new to me 9a. I picked it up about 6 weeks ago and after extensive cleaning, mounting on a new table, and getting a drive flat belt in place was able to turn it on. Yeah!! That was the good news. The bad news is there is a squeak in the spindle. I started by turning off all everything, the forward / reverse lever, and the back gears, and the bull pin. The squeak remained constant with each change. The squeak remained the same with the bull pin in and out.
This leaves the only constant moving bearing the rear bearing, the parts list labels this 'thrust bearing'. I have ensured the bearing is adequately lubricated.
Has anyone had this issue? Is there an adjustment? Is there a replacement part?
Thank you in advance for your input. Dan
