Hello,
The recently acquired SB 9A 3.5' bed lathe I have was using grease in the gears and QCGB. I am in the process of removing all the grease and replacing felts as I go. I have the forward and reverse lever out, but am hesitant to be too aggressive in removing the gear pictured. Should I be able to tap the shaft out of the center of the gear to remove? How should this assembly look when together all the way?
