Sources for 353 brass
devils4ever
H-M Supporter - Gold Member
May 13, 2019
1,016
I'm looking to build a clock and started pricing materials. The best brass to use for clocks is 353. I priced it and I'm in shock. Onlinemetals.com has 3/16" X 12" X 12" 353 brass for $652! At McMaster-Carr a piece, of 1/4" X 12" X 12" 353 brass is $324!
I may have to use something else. I looked at an older post here and the prices seems to have doubled in 4-5 years!
Any thoughts?
Try eBay, lots of vendors there selling all kinds of metal in small quantities.
Brass prices really spiked last year, I bought some flat stock from McMaster-Carr in the wrong size January 2021, went back a couple months later to get the right size and prices were already up about 50%.
I’m not a clockmaker, so was curious what 353 is and if 360 would work since it seemed to be very close, and came across this forum post.
It sounds like the main difference is the color, if you don’t care about that, then 360 might be a cheaper alternative. I buy many of my materials from Midwest Steel Supply, they don’t have 12”x12” sheets of 360 brass, you can get 260 in that size, but their prices are usually pretty good compared to other places.
I'm not that concerned with color, but is 360 close enough to 353?
It depends on what parts you are making, it appears that 353 would be better if you are engraving clock faces and things like that. For mechanical components, it is slightly stronger since it has less lead, but doesn’t look like enough to be an issue. I found a reference to it having better formability than 360, so if you are bending parts, that might be the better choice. Other than that, I could not find anything to indicate 360 would not work.
While searching, I came across this link for a better price on it than McMaster-Carr.
Yeah, they look better on price. Thanks for the link.
