- Apr 12, 2013
- 562
Here's the setup. Everything has been running fine for an hour. I finished cutting a 3/4" rod of mild steel down to create a 3/8" stub about 1" long in prep for threading 3/8x16. I changed the QC gear box off .048 feed rate to set for 16 TPI. (Yes I've used that setting recently...just last week threaded another exact same setup 3/8x16) I set the bit, get ready for a scratch pass to start threading, flip the power switch on...
...and the chuck spins once or twice and stalls...belt squeals...I hit the power off ASAP! No pop, snap, bang, etc...it just went from fee spinning to belt squealing. I never had time to push the belt tension lever forward to lock it in...just the loose belt friction is normally enough to turn the chuck freely and full speed when not cutting.
Disengage the leadscrew and everything rotates fine.
With leadscrew engaged, it is dragging badly. The gear train on the left of the headstock seems loose and free (rocking the chuck back and forth, within the confines of gear slop they rotate fine). Drop both QC levers down (disengaged) is no help. I reversed the lead screw direction and it would turn (with high effort) as I turn the chuck by hand. Go back forward, and get the same...high effort to turn the chuck by hand with leadscrew engages, spins freely when disengaged. I tried several settings on both QC levers, little effect.
Anyone with a suggestion on where to start, or do I start pulling the leadscrew and QCGB right away?
