- Feb 17, 2014
- 97
I just wanted to share some of my first CNC projects. Nothing too fancy, just machining to learn. Both these were done on a Tormach PCNC 1100.
2.5" Turners Cube
I used the probe that came with the Tormach to center the edges on each side. It made things pretty easy and fast. This was also my first test with some Carbide Maritool 3Fl 3/8" EM's. They seem to work fairly well.
Some Engraving tests:
It seems that the fly cut (Super Fly Cutter is really fantastic!) on the engraving face has a small step, so I'm assuming that my tram is off somewhere. I need to check this.
I'm looking forward to making more progress with this machine. As my Work picks up, I'll be working on some prototype parts and probably some short production runs. This should help speed-up the learning curve.
Eric
2.5" Turners Cube
Eric
