Hi all, newbee here. I just finished adding supports to my bench atop which my 9A SB sits. The garage floor had a surprisingly steep slope to it so added a railroad tieplate and some steel shims to the legs. I'm using a regular level, not an expensive professional one. So I'm pretty beat today from working.
My next step is to take off as much old oil stains and possibly grease stains and rust as possible. I purchase naptha and brakeclean and plan to use those on the way, gears, apron, outside of motor, etc and then use the A, B, C oils for spindle, ways, etc.
Not sure if I can use a steel wire brush on the ways as maybe this might damage the ways? Maybe brass wire brush? or just a rag?
anyway, I'm sure there's a question or 2 in here.
I'm guessing I don't need to purchase grease for anything as everything uses special oils.
I don't want to run the lathe until I do all the maintenance first (I did run it for about a minute to ensure setup)
