I remember a discussion a while back but couldn't find it in my search.
After watching Robrenz's video several time I have a question someone here can answer i'm sure. I don't understand the dowel pin he's talking about. Did he actually drill a hole for a pin? Does the pin also sit in the base? Are there two other holes drilled into the tool post for the set screws to push against the dowel pin?
Also, you'd be limited to only using inserts for this type of set up as you would not be able to move the post, correct?
