- Mar 25, 2018
- 131
Now trying to choose between the Shop Fox M1099 and the PM-1127VF-LB.
What say y'al ??
Get the PM. The service alone from Matt is worth it.From restoration to general service the vintage Logan was a lot of fun for the past few years. But I think I have it sold.
What say y'al ??
Please buy a 12x36 at least
I have the PM1127 and you have to change gears to do some threading.. and change them back again to feed rates. It's a serious pain.
Yes, I wish they offered a fully selectable gear threading system. I had to change gears and/or gear positions for virtually every change in threading operations with the Logan. I am told that, even though some gear changes are necessary for threading with the PM1127, it isn't necessary to make those changes for every change in threading operations. Is that correct?
Yes, that's correct. My Logan was a circa 1940 model that was made by Logan for Montgomery Ward. It was a well made lathe, rugged and accurate. But, even though I had a complete set of nearly new change gears, it did require that the gears be changed for EVERY different threading operation. Even though some of the newer lathes below 12 inches require some amount of gear changes for threading operations, they have a higher level of selectivity, broader selection of spindle speeds (the Logan was limited to six speeds 45 - 1300 rpm) and left hand threading options that the Logan didn't offer.Why did you sell the Logan? What are you looking for in a new lathe that the Logan didn't give you?
Neither of the lathes listed seem to offer a lot of advantage over a 10" Logan (assuming since those are the most common), other than spindle bore particularly if it was a QCGB model. Edit I see your last post mentioned change gears so it sounds like yours didn't have a QCGB.
