software prefrences
gahux
Mar 8, 2013
13
I'm new to the site and am trying to get a feel for what help is out there. I have built several CNC machines over the years and been an avid user of the Mach series of software since it came out. My question here concerns what most people use for CAD/CAM software? I have used Alibre since the days that a person could get a free version for home use for all my CAD design. I have used a variety of CAM (g-code generators) depending on $$$ available and the task at hand. Started with Deskam and moved to Vectric 2D and now starting with Dolphin. I have tried just about every CAM package I could get my hands on but always found it difficult to learn them before the trial peiod expired. I guess if I didn't have to work for a living and didn't have family/house responsibilities I could devote more time to learning new software. I'm sure others have been down this same road and hope they may help others decide on software packages. We are talking hobby type of needs here, not production facilities. I would love to have a full blown version of a CAM package like MasterCAM, if someone wanted to buy it for me, but my budget can't handle that.
So here are my votes for best bang for the buck:
CAD: goes to Alibre for normal people, a student may decide on Solidworks. I've used both and like them both.
CAM: goes to Vectric 2D for normal 2.5D work with single tool. I use Dolphin for multiple tool work due to budget concerns.
What are your choices and why?
I use the latest versions of Solid Edge and Gibbs Cam at work. A decent combo but not really in the realm of use or cost for the hobby machinist.
Solid Edge - It isn't as powerful as Pro Engineer or Unigraphics for big scale/complex assemblies but it works well for most things. I find it has a much better drafting package than some of the higher end systems. I've modeled stuff in ProE and exported it to SE to make a drawing package because of the time savings and simplicity. SE isn't that hard of CAD package to learn. Fairly intuitive and once you learn one package it usually isn't hard to use another. They use the same modeling concepts with different button and tab placement.
Gibbs Cam - It has quirks but it does a decent job producing code of the multi-task machines I work with (5-9 axis). I find it a little cumbersome for simple 2.5D stuff and do a lot of manual coding and check it with software such as Cimco Edit and NCplot.
I have an older hurco mill and was able to buy BobCad/Cam real reasonable and have easyDNC5 as a communication program, i am trying Predator but have some problems talking during dripfeed, BobCad I've had to rewrite my post processor but it appears to work good
for almost everything i do with my mill i use d2nc it imports dxf and i think it's about the easiest to learn
for hobby use it is pretty powerful and written by a machinist that uses it daily
it is 2d but it also does 4th axis
if you go to d2nc.com there are videos to see how it works the videos at the bottom of the list are the new versions and for dxf import
it also has a drawing section i dont use but is in the first videos
it's $79 and well worth the money
i have no relationship to this company i just love how easy it made it for me and i tell others
artsoft mach3 shows it on their website and it incorporates right into mach3 for ease of use
steve
Is there any worthwhile software that runs on Linux (or on WINE in Linux)?
I run LinuxCNC; QCad for drawing, dxf2gcode, or pycam for CAM, and LinuxCNC.
Seems to work fine; getting to grips with pycam, it will eventually replace dxf2gcode.
Cambam also has a linux version out; we'll see if I pick that one up.
So far, I have purchased only QCad; the rest is open source, and is fine.
Some think that Google Sketchup is fine for 3D CAD - seen some really good things come from it. Not used it for the workshop, though.
+1 for pycam, i'm a huge opensource supporter. nothing like drawing in inkscape and importing to pycam for gcode FOR FREE! love it love it love it!
I am a former owner of a real CNC shop and I was a GibbsCam user there. When I sold the shop the new owners didn't want my GibbsCam, they wanted to use MasterCam, so I brought my GibbsCam home with me. I had a little over $18,000.00 invested so I wasn't about to just throw it away.
Now I use it in my home shop where I have a Tormach PCNC 1100 in the garage that I use to make parts for gasoline powered remote control race boats.
I have tried BobCad V23 and it was WAY too cumbersome for me. I had a bootlegged copy of Mastercam 9. I loaded it and worked with it for about a month, even bought a training video, After about 6 weeks I took it off and gave the disk to someone else.
I find my GibbsCam to be far easier to use than any other program I tried. Some will say theirs is easier to use. I think it all comes down to what you were trained on.
For the most part, GibbsCam is probably not practical for the home shop user because last time I checked, it starts at about $5,000.00.
I have a HAAS TM2P:)) mill and a YAM lathe using LinuxCNC:)). I use BOBCAM VER25 for the mill and lathe. Once you have worked with BOBCad's paradigm it it is not bad and the cost is resonable. For most things on the lathe I use NGCGUI (subroutines built inside LinuxCNC) and all is good and easy.
Jim
draftsight(free) for drawing 2D.
Vectric 2D for cam.
Mach3 for controller.
2'x4' cnc router in the works.
