- Aug 4, 2015
- 291
I had a thought for those that are trying to put a CNC project together and having problems with the idea of buying ball screws for their mill / lathe and fitting them to the machine. If a CNC program was created that took the output of some of the less expensive DRO scales that are being used with a tablet or other device and actually looked at the table position for making a cut, the backlash of the standard screws wouldn't be relevant. It would simply go to a position on the DRO scale and be in the correct position as long as the scale was accurate. By this I mean if the X axis was to make a cut of 1 inch from left to right then back up .5 inches and then the Y axis was to cut in some distance. the backlash on the machine lets say is .1 (alot but easy math). The machine will return to .6 and not .5 due to the take up of the back lash. If the DRO was referenced then the table would return to .5 because your not counting turns on a stepper motor, you are actually referenceing table location.
I think this would get alot of people past the hump of converting machines due to the cost and complexity of ball screws and a machine tear down and retrofit of the ball screws.
I realize that there are specific kits for Bridgeport mills that the screws are a straight forward direct drop in, but something like an Excello 604 (what I have) is not gonna have a direct fit, no modification needed ball screw kit to convert it.
I know there is Moglice (or something like that) to use to drill out the threads on the nuts and rebuild the nuts on the machine but that frankly is scarier than the ball screw retrofit as drilling and ruining nuts that can't be simply replaced off eBay for a few bucks.
Don't know if there is a programmer out there that would want to take this on, but if so, there's your concept for it. If you choose to take it on I claim no patent on the idea, but would ask for a copy for personal use.
